RM80 Oil Height?
Posted by: placelast---------------------
Now that my son's seals will be replaced, what oil level height works best 4 U guys out there?
Is the measurement taken with RT emulators in or out?
I posed the 1st Q a few months back; thanx for the help but failed to write down the height - will do it this time by scribbling in the manual.
Posted by: shockdoc---------------------
You will want to set the height with the emulaters in, springs out and fully collapsed. Depending on what rate springs your using you will probably want to be between 4 & 5 inches from the top.
doc
Thanx, Doc.
The manual said 4.3", & gives a + & - range, but since the emulators take up volume, I figured that may change the equasion.
I'll go ahead w your suggestion.
Posted by: rob mann---------------------
it would change the equation if you were to put in a measured volume of oil lets say 375cc then you would have to minus the volume that the emulators take up. but becuase you put the emulator in and take out oil to a measured ht. you are compensating for the added volume that it takes up. I would recommend 110mm for a oil ht.
