Originally Posted by Masterphil
Once they start moving, they tend to close up progressively faster each time they are shimmed. If you've dropped more than 3 shim sizes from stock, the valves are in danger of snapping off the heads and need to be replaced ASAP.
Originally Posted by skipn8r
But since you aren't the original owner, you don't know if the shims have already changed 3 sizes..... or 6.... or.....
