Difference between Service Honda and...
Posted by: elliot-cr133---------------------
What's the difference between a Service Honda CRF250, and a regular CRF 250? Is it just the graphics kit? Pardon me for being the newbie here, but no one's ever really told me, nor have I been able to find an explanation on here. Thanks in advance.
e.
Posted by: Chili---------------------
Service Honda is a Honda dealership. If you were looking at the CRF250 then there is no difference. Service Honda does however cater to the custom bike market with models such as the Service Honda 500 AF (CR500 engine into a modern CRF frame), 500 AFX (off road version) and the Junior-X (CRF250X engine stuffed into a CR85 chassis). CHeck out their site http://www.servicehonda.com/.
Posted by: mxneagle---------------------
Doesn't service honda put a crf250 motor in a cr80 frame or something like that?
http://www.servicehonda.com/images/...or_Logotype.gif
http://www.servicehonda.com/junior.html
http://www.servicehonda.com/images/250xjr/Junior.jpg
Attention All Off Road Enthusiasts:
Junior is one serious trail bike that is serious about fun for riders both large and small. For many smaller riders it is the bike they have been dreaming about. For larger riders this is the ultimate fun bike. Junior will allow the whole family to ride together and have fun on even the most challenging ride. This exciting bike is nimble, lightweight, well suspended, electric start and packed with power.
Never before has a minicycle combined such a high level of performance with a high level of convenience, ease of use, and durability. The Junior-X creates a whole new class of motorcycle by ignoring traditional motorcycle class structure and delivering the bike that many customers have been seeking.
The Junior-X features a lightweight, hi performance chassis with competition quality suspension and a low seat height, strong, broad power, full lighting and electric starting. Suspension spring rates will be selected for the weight of each individual purchaser and are included in the base price.
The Junior-X is available with a host of options. Everything from handlebars to smaller wheels to lower the seat height can be custom ordered to fit your specific needs, all with the quality and durability that you have come to expect from Service. Prices start at just $8,999.
For more information call 219.932.3588, stop in at 5634 Hohman Ave., Hammond, IN. 46320, e-mail gfoster@servicehonda.com
Specifications:
Model Junior - X
Engine Type 249cc liquid-cooled single-cylinder four-stroke
Bore and Stroke 78.0mm x 52.2mm
Compression Ratio 12.5:1
Valve Train Unicam; four-valve
Carburetion Keihin 37.0mm flat-slide with throttle position sensor (TPS)
Ignition CD with electronic advance and lighting coil
Starter Electric & kick
Transmission Five speed
Final Drive #520 T ring sealed chain 14T/ 45T
Front Suspension 37mm fully adjustable leading-axle inverted Showa cartridge fork; 10.8-inch travel
Rear Suspension Pro-Link fully adjustable Showa single-shock; 10.8-inch travel
Brakes Front: Single disc
Rear: Single disc
Tires Front: 70/100-19 (70/100-17 with optional wheel kit)
Rear: 90/100-16 (90/100-14 with optional wheel kit)
Wheelbase 49.1 inches
Rake 27.25 degrees
Trail 92.3mm
Seat Height 34 inches (32.4 with optional wheels)
Ground Clearance 12.9 inches (11.2 with optional wheel kit)
Dry Weight 180.8 pounds
Fuel Capacity 1.35 gallon
Color Red
Specifications and availability subject to change without prior notice.
Posted by: mideastrider---------------------
That looks like a 250 on a cr85 frame. My son would like to take that for a spin.
Price is a little steap though.
