yz125 rear shock spring
Posted by: mxracer535---------------------
I have a 05 yz125 and am 165 lbs plus gear. The problem is when I set the sag the spring is fully decompressed and adjuster doesn't stay lockedso it can spin around, but works fine while riding. I know I need a stiffer spring, but my question is how much stiffer do I need to go? I like my suspension a little on the stiff side and the stock spring rate is 4.7. Would a 5.2 (factory connection) work or should I go stiffer or softer? Thanks.
