Originally Posted by matte1014
If you are looking at the smaller cc bikes I would go with the CRF150 over any of the 125's.. The 150 wieghs more but also is a little bigger and has more power than the 125's.. I beleive the 230's sit around 34 inches where the 150 is around 32 and the 125's are less than that..
Originally Posted by FruDaddy
At 5'4" my wife can easily ride the TTR230, so you would be OK as far as height. Now, if both of your parents work at Honda, odds are you will be riding red.
The CRF230F has a 34.1" seat height, which is comparable to the TTR230's 34.3". Remember that your weight will compress the suspension a bit. The Honda MSRP is a couple hundred more than the Yami, but if you buy on a discount, it'll probably be a wash. They both fall below your $4G ceiling. It doesn't look like the Honda has a backup kicker though. |
Originally Posted by SHSPVR
CRF150R is kick starter only
