89 KIPS NO punch mark on valves!
Posted by: KDXMOSES---------------------
When I ride my KDX in a higher gear lugging around, I can hear that the power valve is just flopping around inside the cylinder. I must have installed the valves incorrectly. The manual says to align the tick or punch marks on the gear heads certain ways. Only my idler gear has the tick mark. How can I align the other two valves correctly without having the punch marks? When the sahft is pulled open, should both valves be open or closed? THANKS
Also, the shaft which operates the valves seems to be able to move up and down, only a few centimeters. Is is suppose to move at all? The small phillips head screw holds the shaft in place?
THANKS
Posted by: paab---------------------
sounds like your actuating shaft is broken. A common error is to loosen/tighten the nut on top without supporting the shaft with visegrips or something...
I just replaced my kips on my 91. valves should be open when the shaft is pulled open, but I don't know how you will determine which tooth to engage without the marks. I guess trial and error moving the shaft from closed to open and watching the valves...
Posted by: jason33---------------------
might be the piston slappin in the bore,or a wrist pin
Posted by: KDX200fromAUS---------------------
Have you cleaned them sufficiently, removed all carbon to see if there really is no marks, when cleaned with thinners, or any spirits they will come up shiny as new, then you should see marks, if there are any......but if not then trial and error is the go, it is tricky but it can be done..
