99 YZ 250 fork setup
Posted by: honduki---------------------
Hi, my hybrid needs its fork seals replaced. What is stock oil height / Vol and weight ? Good place to start from. 85 kg rider. Ride MX and trail
Posted by: airmanloco---------------------
So you specialize in XR200 hybrides huh, I have a 86 200 that I always loved. Anyway, my 06 YZ250 have SSS KYBs forks, I know there different from what you have. Do yours have a seperate damper chamber that holds oil as well? If so 180ml came out of my damper chamber and 252ml out of the outside cartridge. 5 weight oil seams to be common these days and if you want a little softer ride go with 5-10 ml less oil in the outside, althought that will be at the sacrifice of bottoming resistance. Good luck.
Thanks but I think your forks are way different. I cant afford to run a 250F, this is fast enuff to have good races with my friends on our extremely rough MX tracks. Its got an ohlins out the back.
Posted by: Kartwheel---------------------
5wt or 7wt 100mm from top fully bottomed
