Front light not working after reconection- Is there a switch connection
Posted by: SteelHeel---------------------
Hi Guys. I bought a 2006 model KDX that has had the light and odometer taken off to be replaced with a CYCRA works number board. I have fitted the odometer and light back. I have connected the wires under the tank, the black was cut and I had to reconnect it. The other two wires just clipped in to one another. I started the bike and no light came on. I also noticed that there are two loose wires near the connection on the light and wonder if this model comes with a switch on the handle bars. I didn't see any marks on the bars?. I live in South Africa in case there are different models for countrys.Please help ? Thanks Steelheel.
Posted by: John Harris---------------------
US bikes come with an off/on switch on the handlebars that controls the headlight and tail light together. Read other threads on here for lots of lighting information.
Cheers John
Posted by: muddertrucker---------------------
Did you check to se if the light bulb was ok? Sometimes the simplest little thing can slip by unnoticed
Thanks John will do.
Yip check that first. I have since got myself an owners manual and all is in there. Yes it has a switch. Thanks mud.
