Originally Posted by Matt90GT
FYI it is an 03 bike, so there is no red knob on the carb for the hotstart. It is the lever on the bars, the short one
Originally Posted by nikki
If it's not as simple as using the hot start, you should check your valve clearances. They might be getting tight when the bike is hot, making it hard to start. Here's a link I posted on how to check the valve clearances on the YZ250F. There are also good instructions in the manual. Give yourself an hour for the first check, but once you get the hang of it, you can do it in about 20 minutes. You should do this every 10-15 hours, or if the bike is ever hard starting.
http://www.dirtrider.net/forums3/sh...ighlight=feeler |
