klx300 shifter gear torque specs
Posted by: tonibaloney---------------------
i've looked at my manual, but i'm not sure what it's actual name is though. how many ft lbs do i torque that little nut to. the one that holds the shifter gear in. it's a 6mm'er. general torque was 8.5 ft lbs, i think. let's see...
it's a 6mm bolt, not nut. thanks for everyones help
Posted by: phranticness---------------------
Make it snug. Hold your ratchet at the head, and tighten, When you hold it at the head the torque is much less than at the handle. I personally don't think a shifter bolt requires a torque wrench. But if you have to torque it, 80-90 in lbs Is about right
yes, you're right phrantic. it didn't need much for tightening. no torque wrench necessary. thanks for your input though!!
