crf 450 gearing help
Posted by: shelton88---------------------
What is a good sprocket setup to start with for tight courses?
Posted by: Spokes574---------------------
I would not go up more than 1 tooth on the rear.
Stock is 48. 49 will help pull faster out of corners.
If you go higher than that your power spread will be shortened and the CRF450 gearing is real good as is.
For tight tracks you want more bottom, so a pipe that gives more bottom or revs faster would help you.
I know the FMF 4.1 power bomb helps with bottom and mid but is quite expensive. I would try the 1 tooth sprocket
first its a cheaper solution.
