Originally Posted by jtm994
I put the engine oil on the right side and the transmission oil on the left side where the dip stick is right? but what does the dip stick on the left side measure, the engine or transmission?
Originally Posted by Ol'89r
The engine oil goes in the left side and the trans oil in the right side. The dip stick measures engine oil. I would recommend looking at a service or owners manual for the correct amount of oil for the transmission.
what kind of oil goes in the transmission
I have had good luck with Mobil 1 10W30. If he doesn't want to go with the expense of the synthetic oil, any good grade of 10W 30 will work. Main thing is to change it often.
so the engine is 10W 40 and the transmission is 10W 30 or could he put 10W 40 in both?
Originally Posted by mafols
There is a hex head screw with a philips slot in it and a brass washer just below the water pump on the lower right side(clutch side) of the engine. This serves as an overflow. Fill until the oil starts to come out of the hole. Be sure to wait until it stops coming out before putting the screw back in because it takes a while for the oil to drain through the small hole. Otherwise it may be left with too much oil in it.
