Originally Posted by 150rguy
...Im going to be building a double above my house...
Originally Posted by High Lord Gomer
You sure your parents won't mind you riding on the roof?
Originally Posted by HajiWasAPunk
something to keep in mind when building your own double, the maintenance on the first jump. Say you're comfortable with a 40 foot double, or single to table as you're describing. When the launch angle gets worn out on that single, that is now a very dangerous jump becoming harder and harder to clear.
Do you have access to the equipment to keep this up? Otherwise stick with tables, even when they get worn out they can still be fun and you don't wind up looking like wiley coyote after a cliff fall. My 2 cents from building a maintaining a small track on a 3 acres. |
Originally Posted by cawkazn
this is something else to think about. if you decided to go with my sugestion you wouldnt have to worry about maintaining it much. you might want to check this link out.
http://images.google.com/imgres?img...-1%26safe%3Doff |
Originally Posted by FruDaddy
If you do decide to build a ramp to help you learn to clear a gap. you should cut it down a bit shorter than a standard FMX ramp. In the pic below, I noticed a joint just above the guys waist, this would be a good place to stop building. Keeping it shorter, and less steep, will keep you from being chucked too high into the air.
http://www.fmxschool.com/images/ramps_sidebyside.jpg |
