Originally Posted by 2 strokes for life
Alread tried that. This thing has paper thin walls and a huge piston. It is not the jetting at all. I had to go up a hole bunch on the main so it would bog the bike down at higher speeds.
. It'll do for now. Hopefully by next weekend I'll be
mxbundy, i shall try the double base gasket this spring.
Britt Boyette, the carb is fine. I think it is the high compression. |
My clutch has to have a 20 or 30 pound pull to it.
rd400pi, i am almost sure they made a 83 IT465. I doubled up the base gasket and head gasket and it works. It also beats most 250 2 strokes or 450 thumpers on the strights.
