running KDX without lighting coil
Posted by: arjay---------------------
Hi there, just after a bit of ignition advice.
When I pulled apart my 87 motor for rebuild I found the lighting coil was broken (windings hanging out). I took it out and pulled its wires out of the loom (green and yellow).
Is it ok to run with just the ignition coil?
A quick spin of the crank by hand gives a pulse of around 3v. Does that sound right? Is that low due to the speed of the turn or just low full stop?
Posted by: chicoman---------------------
it'l be fine without the lighting coil.
Posted by: Tusk---------------------
My brother's 200 has one, but it's blown. It just needs replacing. No headlight anyway right now.
The bike runs fine without it.
