. it'll be hard to find a bike that will fit you for under $1500, but 125 might do you well. it doesnt require a lot of maintenance and runs very well with the proper gas/oil ratio and when the jetting is set. look at used Yamaha YZ125's, the are more expensive than the others, but youll need the extra seat height at 6'0''.
. I wasnt sure if the KX100 would be ok. I sit on one at the local dealer, and it did feel a tad bit small, but not too awful bad. I didnt realize how cheap I could get a used YZ125 though! Didnt even consider looking into one since the MSRP is over $5k. I will do a little more looking around at Hondas, Suzukis, and more Kaws. Any major differences between them when it comes to the 2-stroke 125s?
Originally Posted by gsimpson2g
. I wasnt sure if the KX100 would be ok. I sit on one at the local dealer, and it did feel a tad bit small, but not too awful bad. I didnt realize how cheap I could get a used YZ125 though! Didnt even consider looking into one since the MSRP is over $5k. I will do a little more looking around at Hondas, Suzukis, and more Kaws. Any major differences between them when it comes to the 2-stroke 125s? |
. my dad is 6'0'', and he makes my 125 look like a toy, so because the YZ is a good bit taller, i would lean towards that.
