V force reeds vs. Power blade power now
Posted by: Evins---------------------
which one would best the best pick for my yz85?
Posted by: 2 strokes for life---------------------
That is hard to say but i do know that the powerblade is alot cheaper. Wich everone you go with tell me how it works.
Posted by: john stu---------------------
i would say v-force all the way
price is not an issue.
Posted by: foxracinggirl---------------------
I bought a V Force 3 about 2 1/2 weeks ago. I installed it and changed the jetting. I like it alot. I say go with V Force.
Posted by: whenfoxforks-ruled---------------------
Hands down,your choice should read,a very good reed system to enhance throttle response or put a restrictor in my carb?????????????The hot setup used to be making your carb bigger,does putting something smaller make sense to you? If you knew pressure went through your carb in a wave pattern then why disrupt it???This thing in a race bike will calm it down and make it more manageable in the trails,so would dragging a small block chevy engine!
