Suck oil from the fork
Posted by: Charlie Mix---------------------
I need to reduce the oil level on my fork (Kayaba UD 46).
I've tried to suck it out with a syringe by means of a little plastic pipe ( dia. 80 mils) threaded in the bleed hole, but I'm not able to reach the oil inside the fork.
Anyone have a solution to do the work without disassemble the fork from the triple clamps?
...and avoiding to put the bike upside down !
Posted by: FruDaddy---------------------
Pull the bar out of the way and take off the top cap, but that doesn't take the place of doing it right.
I've ended to dismantling the fork so now I can answer to myself.
It wasn't possible to suck oil from the bleed holes, because of the bumpers installed under the caps.
...and it wasn't possible to suck oil simply removing the caps with the fork installed, because with the rods completely extended the oil level is too low.
The only way to decrease the oil level is to remove the fork from the triple clamps, open the caps and tilt the fork until the oil pours from the outer tube.
Posted by: jason33---------------------
or take off the cap and tilt the bike over-
if your going that far you might as well replace all the oil in bolth forks-
