2003 CR500AF Service Honda
Posted by: SPEEDKING---------------------
Jeremy,
As I think you know the 2003 Service Honda used 2002 frame and suspension components.
Stock it comes with .44's and 4.8 or 4.9 rear shock. Both felt way soft to me.
I weigh 185lb and 225 with gear (tools, camelbk, etc) when riding enduros/qualifiers and Hare Scrambles. I'm less weight when running the Hare Scrambles...maybe 8lbs. But, add into the equation a 3 gallon tank plus 7lbs of the 500 engine over the 250.
I run a reasonably aggressive pace in the A class in both Hare Scrambles enduro/qualifiers. The guy I bought the bike from says he has your valving so I think I need your opinion on spring rates front and rear.
Posted by: +30---------------------
Wow 40 lbs of gear, thats got to wear ya down. I noticed no one has replied all I can think of is go to racetech.com and check their spring rate generator listings. The stock 4.9 sounds soft to me too. (consider that a stock 04 rm 250 for example has a 5.2).- thats the highest of the bunch but just illustrating a point. I would think your undersprung how does your race sag and static sag look when your all geared up.
Posted by: MRW---------------------
I`m thinkin 5.8 and .50`s with gear on.....I ain`t Jeremy, just bored
Maybe .49`s with MX-Tech pistons.
Posted by: whenfoxforks-ruled---------------------
You need to talk to Jeremy or Brandon,it sounds way to soft for your ap. Maybe he has another store closer to you.
Posted by: Pete Payne---------------------
Go with a .50 up front ang a 5.4 out back .
