Your springs would b e perfect for you if you lost about 120 lbs(no offence) They say that stock springs are good fo riders who weigh in at about 135 lbs. I changed my springs this winter while I had the forks out. Just to change one spring is probably only 5-10 minutes.
Originally Posted by supajdogg
What's wrong with the springs? They seem ok to me. I'm 255lbs so I'm sure they're too soft for me, but I stiffened up the compression dampening a bit and they seem ok. From the manual it looks like a real PITA to change the springs. Is this true?
Looking at my plug I would say the jetting is ok stock, just a bit rich. What are the stock jets? |
Originally Posted by John Harris
Put the clip in the next to top position--nearly everybody agrees on this. I suggested jetting before. With suggested jetting about 1.5 turns out on air screw and turn her on! Cheers John
Originally Posted by Makeshoes
In my opinion, for what its worth, I would think about a different oil. We ran Klotz racing oil, in the woods, and not happy about what things looked like on the inside of the engine. While its a good oil for certain applications, I think there may be a better choice for woods riding. Just my 2 cents.....
