Originally Posted by CRF59jk
Yeah, I really do have around 500 hours on the bike.
WOW! thats alot of stuff. I think im just gonna replace some seals, check the valves, change coolant and brake fluid, clean carb, and change fork oil. |
Well actually when I really think of it. I only ride 3 days a week in the summer and I ride 2 times a month in the winter. I compltly forgot about that.
So I would say I have 150 hours on the bike actually. Im sorry |
Originally Posted by kurt15
check the linkage on rear suspension and grease bearings
Guys I dont know much about all the engine parts so you will have to explain.
^ I have wanted to do that, but I dont know what to tell them what I need done,
Originally Posted by Rich Rohrich
If you really have the 150 hours on the engine that you claim then you are due for the following :
Valves (all 4) Valve springs Valve seals Valve job Cam chain Cam chain tensioner Piston, rings & piston pin Diamond honing of cylinder MAYBE - Crank MAYBE - Main bearings MAYBE - Exhaust rocker (assuming the usual amount of wear) Water pump shaft, bearing & seals Counter shaft seal & possibly the CS bearing Steering head bearings Clutch plates and basket at least needs to be carefully inspected That's just "normal" wear stuff for the hours you are claiming. |
I figured it isnt that hard. All you have to do is read the damn service manual and put it back together.
Seems like it just take up time. |
Should I take the hole engine out? Or just leave it in the bike?
I have around 40-50 hours on my 450.
Originally Posted by Chili
And then while perusing TT tonight I find this...
So we've gone from 500 hours to 40-50. So in following the trends by this time next week it will turn out you actually own an 82 XR100 that you haven't actually rode yet because you can't get it started. ![]() |
Good catch Chili.
Too funny.
Why do people feel the need to make ridiculous proclamations about the amount of hours on their 4 strokes?
We start with.... Then when called on it by experts we get.... And then while perusing TT tonight I find this... So we've gone from 500 hours to 40-50. So in following the trends by this time next week it will turn out you actually own an 82 XR100 that you haven't actually rode yet because you can't get it started. ![]() |
Tomorrow I am ripping the hole bike apart and cleaning it and looking over it all. I figured it isnt that hard. All you have to do is read the damn service manual and put it back together.
