KDX Crankcases
Posted by: longerdeeper---------------------
I have been patching up my 1999 KDX220 crankcases for some time now, after the typical 220 piston break down. I have got a good surface contact between the cases but several cracks keep appearing, I have tried to fill with epoxy allunimium filler etc etc which improves things for a few months but it is now getting frustrating.
It is time for me to do something proper about it; like scrap the thing or fix it up and sell it quick, - both options I'm not keen on because I still quite like it.
So has anybody know of any crankcases lying around, I believe any from '95 to '07 200 or 220 are all the same?
Or has anybody got contacts on where I could buy new or second hand?
Any help would be appreciated!!!!!!!!
Posted by: Backslayer---------------------
Hey I looked on fleabay and seen nothing but you should check out service honda they got kawi parts now and they got to be the cheapest youll find , I had to buy the left side crankcase for my cr 125 and it was only 166, as aposed to 265 from the honda shop good luck
I did some searching for you You have to buy the cases as a set your part number is 14001-1212
www.mrcycles.com 339.33
service honda 328.44 but it said sold out in the fiche prog so you would have to call on that one
www.babbitsonline.com 373.99
Posted by: John Harris---------------------
Try Jeff Fed. He might have a whole lower end that is cheaper than new cases. He might also make you some other constructive suggestion. Check around! John
Thanks Guys!
Jeff F got back to me quick smart with $250 for reconditioned second hand cases with exchange.
I had found the Babbits site
Thanks for the heads up w.r.t service Honda and mrcycles.
I guess I need to decided how much to spend on it. I should get the Barrel replated. I had a couple of KX80 Barrels done recently at U.S Chrome and was happy with the result and service.
Thanks again for the help!
regards
Chris
