No fouling. And it's a rookie rider.Lots of plonking around. Not haulin @$$. |
Originally Posted by Rotorranch
A new plug often cures the problem, but not the cause.
Jetting and heat range go hand in hand. The KDX that stays here is on the same plug since this spring. No fouling. And it's a rookie rider Lots of plonking around. Not haulin @$$. We run 8ES here on the KDX. 50:1 Golden Spectro. Amoco 93. Can't recall the jet numbers offhand, but dropped the needle one notch, and one smaller on the pilot from stock. Rotor |
Originally Posted by BSWIFT
Most CDI units need the "R" plug. It can cause unusual problems that are hard to diagnose. Better to use the "R" plug but the non"R" plug will work in a pinch.
