Originally Posted by flyingfuzzball
are you sure thats your little bro you look exactly like each other LOL
nice lookin bikes. |
Originally Posted by RM85rider123
whats the seat height on both bikes?
thanks for the response, but since I am about 5'3 and I can fit a 34.4 inch seat height, do you think I could fit something the size of the XR? Thanks
Also, how often do you have to change the oil that we were just talking about?
Originally Posted by 2 strokes for life
XMotoX, not to be abrasive but by putting in less oil you are giving the engine more gas making it more rich. If your bikes ever foul plugs its because of jetting not fule mixtures. I have ran 16.7:1 in one of my bikes and the results are better then that at running it at 32:1. If you are using a regular mixing oil (non-synthetic) i would not go too much past a 32:1 fule mixture. If you are running a full synthetic such as AMSOIL DOMINATOR you can run a 50:1 mixture safely and a 100:1 if properly jetted to that mix ratio. Just pitching in.
XMotoX, so young. I once was the same way when i was new.
http://justkdx.dirtrider.net/ go there, go to tech tips on the left hand side and then go to carb tunning and go past 2 diagrams ( one of a carb abd the other of jets for slide position and there should be a big stop sign and read what it has to say. |
