Bike Maintenance
Posted by: roger69---------------------
I Have A 1998 Honda Xr80 What Type Of Daily Maintenance Needs To Be Done What Type Of Oil To I Use And How Often Do I Change It.and The Air Filter To...thanks...
Posted by: 2 strokes for life---------------------
Clean your air filter every ride or every second ride and as for oil i do not know.
Posted by: _JOE_---------------------
Clean the air filter when it looks dirty. Change the oil a couple times a season. LUBE THE CHAIN. The chain/sprockets are likely the only thing other than tires and brakes that will ever wear out on your bike. Those xr's are bulletproof.
Posted by: defo26---------------------
Depends on how you ride. On a xr80 you probably arent killing the engine like a motocross bike so I would say change the oil every 4 rides or 10 hours. For your air filter you should buy an extra one so you can ride with one and after that ride clean it but have another clean one ready if you want to ride the next day. Change the filter every ride.
