crf250r magnum billet clutch basket
Posted by: CareF759---------------------
Just bought one of these and for some reason the gear wont slide in... the teeth all line up and my gear is in good condition. Could this be a manufacturing error? The basket is for a cr125 and crf250 which i know is correct. anyone else heard of this? should I send it back and try again with another magnum or a different basket?
Posted by: confusedtech---------------------
I bought a vortex basket and it was the same way. Mine came with instructions to freeze the inner gear and heat the basket,that helped some but I still had to press it in. I have not had any problems so far.
Thanks for the reply....whats the best way to heat up the basket and press in the gear?
Posted by: flounder---------------------
I would say just throw the basket in the oven on 350 for a little bit...
Posted by: krosser---------------------
Boiling water works well if you are quick.
