Originally Posted by whenfoxforks-ruled
Israel! Well it says you do not know where you live, just a flag. Wire your ap adjuster, or a zip tie. Can you order a JD jetting kit? He would know exactly which leak jet to put in there, and maybe a pilot jet change. I am pretty sure its got something to do with the ap circuit. The leak jet may be clogged. There are some really small o rings, one is atop the mixture screw and the other is in the accelerator pump cover. Their mis alignment can cause a hesitation also. Leak jet, yamaha calls them something different, its the one in the bowl.
Originally Posted by R.P.M
im not sure about the defenition of missing for example.
mybe missing is the word....but i will choose cutting. on/off on/off. and thinks the valve are fine (but listening - the motor sound timed well). i hope that soon we will get anther bike and we will replace the CDI/COIL and check them. anyway he want first to eliminated that neutral unit wire. i guess that i wont be lazy and i will remove the fuel tank and disconnect it. |
Originally Posted by Ol'89r
R.P.M.
Cutting on and off would be the same as 'missing'. That would also be different than bogging. I would remove the gas tank and disconnect the wire instead of cutting it. While you have the tank off, check all of the wire connectors and wires for loose connections or broken wires. Remove the kill button and try it again. Make sure your breather hose that is attached to the top of the engine is not plugged with mud or kinked /obstructed in any way. Check your valve adjustment. Tight valves can cause many problems and the only way to tell if they are ok is to physically check them. If you still can't find the problem then trade the cdi and coil with another YZF. If the bike is 'bogging' or not taking the throttle from low rpm's, that would be your ap adjustment or jetting. |
Originally Posted by mox69
Do you know the total hours or miles on the bike?
Search this website (or the internet) for valve check or valve adjustment. If you have never checked this it would be a good idea to do so. It could be the cause of your problems. It will require something like a "feeler gauge" |
Originally Posted by oldguy
Actually Eric Gorr cut the wire on all of our YZFs the first time he worked on each. I replaced the unit in the engine that the wire ran to with a site window so I could verify oil level with a quick glance so I guess cutting the wire is a safe move.
RPM to set the jetting it is also important to work with air temperature as well as elevation. Do you have the Yamaha manual for a referance on jetting? From what I remember there is a chart in it that gives recomendations at temperatures and elevations. If you do not have a manual I can hunt mine down from the 2004 I have and scan and post it. Unfortunately the earliest I will be home to do it is sometime Sunday (early Monday for you) |
but he claims that what i feel now is happning becuase i need to change transsmision gears. 5th and 3th.
and what should be the price for fixing 3th and 5th gears and timeing chain + cdi ? Thanks |
