mx tech revalve
Posted by: MOTO ON RM250---------------------
the price for a revalve at mx tech is listed at 245$. does that price include new springs?
That's a perfect question to ask the folks at MX-Tech directly.
MX-TECH Suspensions
Jeremy Wilkey - Founder MX-TECH Inc. 1992
office@mx-tech.com
4136 W. 6940 N. Rd
Bourbonnais, IL 60914
Toll Free #: 877-850-5114
Fax: 815-936-9913
good idea. ill have to wait till i get home though. cant use email at school
Chances are good that a re-valve is just that a re-valve, not a re-spring. But checking with Jeremy and his crew is the best way to know for sure and get a few more details on the costs involved.
Posted by: BigRedAF---------------------
Just picked up my suspension for the RMZ an hour ago at MX Tech's west location here in the Phoenix area.
The answer is no.
Jeremy did the suspension on my CR500AF back in 2005 and it's perfect. Based on that I decided to let him have a shot at the RMZ I recently bought.
If your thinking about re valving the RMZ in your profile you might be interested to know that they just finished more testing on RMZ set ups. I'm looking forward to putting in some laps on mine this weekend.
the chances of me getting of me getting my suspension revalved is slim to none. my dad will barely pay for my gas and spark plugs. id have to save up for 1 year based on my 30 dollars a month allowance. my dad wont let me get a job. im prob gonna ask to get it revalved as a birthday present but since im turning 16 im prob gonna get a truck. maybe if i ask for an extra cheap truck he'll budge. tuning my stock suspension seems like the best bet if i can convince my dad that i know what im doing. oh btw my bikes an RM not RMZ
Sorry Dude...
Probably the same fork model with different valving for the extra weight on the RMZ's.
I feel your pain, at 16 I had to choose between a truck or continue racing. I picked the truck and got a job. I started racing again but on my own dime.
what is tuned stock suspension like compared to a revalve?
That is way to broad of a question.
My suspension would buck your little butt right off. Your stock stuff would bottom with my big butt riding it.
There are so many variables. As a sixteen year old of average size and weight I would think your springs are in the ball park. Your valving would be appropriate for your springs. You can make adjustments in accordance with your manual based on your riding conditions.
From your bio I see that your near Clarksburg. Mt. Morris is 45 minutes north of you so I would guess that your soil and terrain is similar. If so your a lucky kid. Mt. Morris rocks!
yeah its about an hour away. ive never been there though. im not really average size i guess. i weigh about 130 and im 5'7. my stock springs are sprung for 190 pounds i think is what the thing on mx tech said
Set your sag at 95-100 mm that's about 4 inches. Set your low speed compression on the shock at 6 more out than stock and your high speed compression at 1/2 turn out more than stock. Set your shock rebound at 4 slower than stock, that's less turns out than stock. These steps will soften up your stroke and slow down the kick back for your weight. On the Fork do the same. 190 pounds sounds a bit high for stock springs. At 130 your fairly light for a 250, if you ever learn to ride this thing you'll get great starts.
These a ball park suggestions and I prefer to be held harmless for your actions.
My wife is from Fairmont, she went to WVU. She knew Davy Combs and he sets us up with passes every year. We visit her family and hit the nationals and make a double hitter out of it.
thanks for info. as soon i figure out what all this means then im gonna change. there is a how to on setting sag on transworld that will come in handy. low speed compression is right below the seat on the right side right? and six more out would mean turn it 6 times to the right? shock rebound is changed by turning a thing on top of the spring right? ive had it for almost a year now and ive gotten pretty good on it but starts are not my friend!
NO, NO, NO...
The two rings on top of the spring?
The top one locks down against the second one. loosen the top one and then grab the spring with your hand and turn it counter clockwise to loosen it so you have more sag or the opposite for less sag.
Low speed comp is the small screw in the middle of the nut on the shock reservoir. High speed is the nut, on my RMZ it's blue. Shock rebound is "H" for hard or "S" for slow at the bottom of your shock near the bottom shock bolt under your swing arm on the right side of your bike.
Turn these screws in clock wise but don't force them or you will damage your shock. They will click as you turn them in. Once all the way in turn them out to the stock setting as recommended in your manual plus the crap that I said above.
On your forks the compression is on the top of the fork cap and the rebound is under the bottom of your fork down near your axle.
Hang tight a few minutes, I'll get some pics to help you out...
This is the comp adjustment. The screw is low speed and blue nut is high speed. Low and high refer to shock shaft speed. Generally hard pack square bumps are high speed problems and sandy whoops are low speed problems.
http://s258.photobucket.com/albums/...nt=P2090067.jpg
This is your shock rebound adjustment.
http://s258.photobucket.com/albums/...nt=P2090068.jpg
This is your spring preload lock rings.
http://s258.photobucket.com/albums/...nt=P2090075.jpg
This is the fork comp adjustment.
http://s258.photobucket.com/albums/...nt=P2090069.jpg
This is the fork rebound adjustment.
http://s258.photobucket.com/albums/...nt=P2090070.jpg
so i use a flat head screw driver to adjust everything except for the high speed comp and the sag right? and im prob gonna have to take the bars off to adjust the fork comp right?
Flat blade? Yes
Bars off ? Maybe
hopefully i get a manual soon and i then i can start messin with this stuff. adjusting your suspension isnt such a dark and scary thing after all
oh and thanks for the tips and pics. they really helped
Posted by: Todd Derossett---------------------
Is Pyramid Valley still open? I can still hear Tom Stout (owner)telling stories about his car wreck.
I grew and lived in WV until 95 when my students loans came due and it was time to leave and find a job.
High Point is still my favorite track but you had better be in
shape. I remember doubling the breaking bumps on the downhills. If you haven't been you gotta go!
A good friend of mine also went to school at WVU and I he was a former top 10 supercross and national mx rider named Steve Childress (www.totalmxusa.com). He was also a 3 time national Amateur Champ at Loretta's and the Mini O's.
I now live about 30 minutes south of Nashville Tn and I go to Loretta's every year and I still see all the Coombs family.
later!
Todd
Posted by: robwbright---------------------
Todd
As far as I know, Pyramid will be open this season. . .
http://www.pyramidvalley.com/
Steve's a nice guy. He was trying to put in a track near me, but the plans fell thru after he had it about 2/3 built. . .
Rob
Posted by: whenfoxforks-ruled---------------------
At 130 lbs the chances are very good you are going to have to put softer springs in. Stock valving is set for stock springs and a rider of about 160. Changing the valving will make a world of difference. Do the springs and save your money for the valves. If you desire to go faster, the suspension is your best bet.
Posted by: minutz---------------------
I'm sure that does not include the springs!
