kx 125 shock is soft.
Posted by: m4i2k2e2---------------------
i bought a 1998 kx 125. someone had the suspension done for a 120 pound rider. i can push down on the shock and it is very soft. how do i stiffen the rear shock? does it have to do with my rebound or compression damping( i think thats what its called, i cant remember).
also, what will the lock nuts on the shock absober do? what i messed with that, will that just increase the height or what?
thanks for all the help.
-mike.
Posted by: minutz---------------------
They most likley changed the spring if its that soft or the shock needs to be rebuilt. Go to the MX-Tech site under support and the tuning guide, it will help you in the set-up.
ok, thank you. what are some signs of a shock needing to be rebuilt?
Any sign of leaking around the shaft or if it has not been done for a year or so depending on the amount of ride time, the oil gets contaminated rather quickly.
he didnt ride the bike for a really long time. i just know he was a really light kid. i mean i can push the rear down easily. i can get it all the way to the bottom but it is just soft. i just want to stiffen it up. its way to soft for whoops and jumping.
