what bike should i get next
Posted by: jasonent0613---------------------
im 15 and i have a 02 cr250 and its getting old so i have been thinking what i get next.
but i dont know my brother said if i got a 450 i would get lazy he said u can ride a 250f just as quick, u just have to ride harder.
what should i get??
Posted by: justalonewolf007---------------------
Give us some more info please!
Fill this out!
11) Your age?
175cm tall, 60kg
2) How physical / aggressive are you?
well i dont like getting beaten i push myself to learn new technieques.
i plan riding on mx and sx tracks but with friends
umm i first picked up a bike when i was 6 but on and off interest for them but in the last year i have gotten way better and now looking at new bikes
umm maybe when i personally can afford it
bike work?
yes
i used to prefer 2strokes but new i like both but i do want a 4stroke because i can go to the gas station and just fill it up not mix fuel and stuff
fraser motorcycles/honda and graem boyed motorcycles/suzuki kawasaki bike shop.
between 6 and 3 thousand dollars
no
11) Your age?
15
no not really
Posted by: rmc_olderthandirt---------------------
Tell us what you don't like about the bike you already have?
Rod
So..you can't afford racing? But you can drop 3-6 grand on a new bike? How much does racing cost in your area?!?!
Any 4-stroke you get is going to feel pretty heavy and not so quick compared to the bike you have now.
Pump gas may be easy, but maintaining a 4-stroke is a decent bit more complicated...
If you seriously need to upgrade, go with a 450. Buy one used, and you should find lots in your price range.
Then Donate your CR250 to me, and I will mix it all the gas it ever wanted! (spoken in jest).
well its a 2 stroke harder to do wheelies and my dad is very tight with money he is only happy to let me have a bike but not race it.
and not long ago i mixed the fuel ratio at 45/1 instead of 40/1 so i melted the piston and rings and snaped the rod for the rc valve.
why a 450
I say get a 450 because:
The power of the 4-stroke 250 is relatively comparable to a 125 2-stroke. In my area, we have those two bikes racing in the same classes.
The 450 4strokes race in our 250 2-stroke class.
Since you already ride a 250 2-stroke, I'm assuming you probably wouldn't want to take a downgrade in performance...
250 hard to wheely?!?! Uhm...are you twisting the throttle? or does it need a new top end? I have never seen one of those bikes have a hard time getting the front end up!
Posted by: SpeedyManiac---------------------
Going from 40:1 to 45:1 won't melt a piston. I bet you were running lean jetting or there was something else wrong. I'd recommend sticking with a two-stroke since motocross four-strokes cost more to maintain.
well it did melt the piston. and im thinking of getting another 250 two stroke because its all ive ever had and less maintanence.
what do use rekon is better the yz250 or cr250
Since you're familiar with hondas, I would suggest that you go with another honda.
If you melted the piston it probably wasn't because of a lack of oil.
Which grade of gasoline did you use?
If you buy a high performance 4-stroke and put the low octane pump gas in it you will melt its piston as well.
Rod
Posted by: _JOE_---------------------
You must be one hell of a rider to be considering a 450 at 15 years old.
i was using unleaded im not sure what the octane was.
well a 450 would be so good but i wouldent use all the power and i would get lazy so i think ill get another 250 two stroke.
not that a 250 two stroke really has less power than a 450 im used to two strokes but i may get a 250f
Go for a YZ250. In my opinion the YZ is the best Japanese two-stroke on the market. In fact it's the only one I'd consider buying. Great handling, great suspension and an awesome engine.
