Originally posted by Streetsquid (Rich, do you agree with this magazines statement)? |
Originally posted by Idaho Charley My first thoughts were what had prompted Thumper Racing to make such a statement? My perception is they are a reputable company and do tend to push the mechanical stress envelope on the new four strokes models. They may have experiences; which us with relatively stock bikes will not see. My opinion is that instead of dismissing the information due to where it was presented, the objective approach would involve contacting Thumper Racing and seeing if this information is based upon objective evidence/testing. |
This just reaffirms my belief.
| The main problem we all see is this: In a built four stroke, the synthetic is just too thin to withstand the pressure on a cam/rocker setup. It also is made thinner by the heat of the clutch slippage and although it doesn't break down in the chemical sense, really thin oil is the same thing as broken-down oil. |
can you go into any more detail on the specifics?
Originally posted by DualSportr The main problem we all see is this: In a built four stroke, the synthetic is just too thin to withstand the pressure on a cam/rocker setup. It also is made thinner by the heat of the clutch slippage and although it doesn't break down in the chemical sense, really thin oil is the same thing as broken-down oil. |
Originally posted by DualSportr The main reason for running a synthetic is that it lasts longer. Oil (especially in an air-cooled four stroke), shouldn't be around long enough to get into the longevity properties! PJ |
Originally posted by DualSportr Why we think petroleum is better: The reason the straight weight oils work better under very difficult conditions? A multi grade oil will break down to its base number - so if you're running a 10w 40, it will break down to the 10w. Not very much protection! The straight weight does not break down in the literal sense. |
) , so if you guys are interested I'd be happy to post some relevant references that can be viewed at any decent engineering library. |
Originally posted by DualSportr Why do race teams use synthetic if it's so bad?: Because race teams have unlimited parts! Synthetic does allow an engine to rev more quickly, resulting in a tiny increase in horsepower. For the pro's, any horsepower increase is good! When you're replacing wear items after every race, and probably replacing a whole engine every couple of races, who cares if the synthetic causes a bit more wear? |
Originally posted by DualSportr As far as the automotive teams using synthetic, of course! It's not tranny fluid! A motorcycle oil does everything; valve train, tranny, clutch. Don't even think about comparing automotive testing to what we do with our small four stroke single engines. |
If the temperatures. and loads are consistent then automotive based oil testing is certainly valid for comparision purposes. To believe otherwise is fairly short-sighted. There is no reliable evidence that I've found in 25 or years of looking to support the long standing myth that motorcycle transmissions "chew up" oils, or that motorcycle specific oils have some magical properties that can prevent it from happening. It's not an accident that many OEM make NO distinction between motorcycle and automotive oil in their owners manuals. The conclusions drawn by the controlled automotive studies have consistently synced with the few motorcycle specific studies that I've seen. Powroll and Thumper seem to be the disenting voices here
Originally posted by DualSportr Some people worry about a straight-weight oil being too thick on startup. In most cases, we kick our bikes a few times before they actually fire up. If you kick your bike at least 5 times before it starts, there will be adequate oil in the head and throughout the system. |
| If the temperatures. and loads are consistent then automotive based oil testing is certainly valid for comparision purposes. |
| On a more personal note, any chance I can get you to send me a new Powroll sticker for my toolbox? |
Originally posted by DualSportr I don't think so. If this were true, then we'd run automotive oils in our car tranny. Since we don't, it's understood that a tranny has different reqirements. |
Originally posted by DualSportr A clutch DOES put oil through the wringer - literally. The increased heat and friction from a clutch puts more crud in the oil and heats it up more than an automotive engine can. |
Originally posted by DualSportr The reason this is difficult to test is that most testers use a dynojet drum-style dyno to do testing. The drum dyno isn't very good at simulating real-world stresses on a clutch/tranny. Using a load dyno you can see more of a realistic test condition, but it's still not the same as what we do when we're flogging the clutch on a nasty hillclimb. |
Originally posted by DualSportr I'm not a big fan of the oil test data that's out there. Why not? because there's test data showing what I believe, and there's also data showing the complete opposite. |
Originally posted by DualSportr Also, none of the major tests are utilizing a single-cylinder ohv air cooled engine as a test vehicle |
The only papers I have directly at hand are :
) | Lubrication of Small Engines - I Mech E C160/78 |
Originally posted by DualSportr I'd reallly like to see this one! When was it written? |
Originally posted by 07 , so why bother with fully synth? |
Originally posted by 07 To look at this from a slightly different angle, whats the downside in using a semi synth. All seem to agree that these are fine, so why bother with fully synth? |
Originally posted by Rich Rohrich I don't think ALL agree that semi-synthetics are as you put it "fine". Semi-synthetic is a pretty generic term that potentially covers a lot of good oils, as well as a lot of piss-poor cost reduced oils. |
Originally posted by Shaw520 07, weather you put 10 miles on an oil change or 10,000, when the engine is running, there is a degree of wear occuring, and the demand of new generation four stroke, ( higher compression, increased rpm, increased valve spring rates/cam pressure, increased temps) the list goes on, all on a single quart of oil. |
eh Rich!), I was merely asking. :confused:
Originally posted by 07 I've no feelings either way |
Originally posted by atk_man If I changed my oil every 3-5 hours I would be very poor! I ride 3-5 hours every day, |
Originally posted by DougRoost WHY 4 stroke dirt bikes share the engine and transmission oils?! Especially with a wet clutch setup. This makes no sense to me but there has to be a good reason. Then again, Honda seems to have come to the same conclusion with the CR450F, though I'm surprised KTM didn't first with their RFS's. And it isn't weight since that was one reason Honda separated separated the sumps on the CR450F.:think |
Originally posted by Max Factor Cannodale beat them both
Originally posted by DualSportr Rich, I'll leave the Syntec question up to you!!! |
| If you change your oil every 1000miles |
Originally posted by DualSportr Hopefully more often than that for a dirt bike. |
Originally posted by Rich Rohrich I've never used it and have never found a compelling reason to start . Sorry
| I havn't had any problems with the clutch, but then again I don't use it too much.... |
Originally posted by DualSportr That's okay, bent shift forks are cheaper than clutch plates. Just harder to get to!:confused: |
| Should I switch this bike to motorcycle oil? Thanks. |
| never use the clutch when downshifting. Says unlike upshifting, there's no load on the gears so using the clutch when downshifting just costs time |
Originally posted by Rich Rohrich The day I start taking oil advice (or ANY technical advice) from THOSE tehno-impaired nitwits, will be the SAME day that pigs fly over my house while I'm standing in the yard holding TWO winning lottery tickets and watching Gomer work on MY bike. :scream: |
| Hey Dualsportr, Which oil do you use? And if I were to switch, would there be any problems? |
I did notice a little oil burn, not as much as my street bike(FZR600). It still showed on the dip stick ....
thanks for your patients and help!!
| How would I go about flushing my oil? Like as what to use and the procedure.?.?. |
Originally posted by RYDMOTO From what I have read,what seperates a true motorcycle oil from car oil is the addtion of polymers to the motorcycle oil for the reason of the transmission teeth and other forces in the transmission. |
