My '04 CRF250R
Posted by: Gage86---------------------
Hey Guys,
I have recently bought myself a Honda CRF250R 2004 and i'm thinking it's about time i dropped the oil... What is the best sort of oil to use for this bike.
Posted by: _JOE_---------------------
You can't go wrong with Rotella. Do a quick search or read this......http://www.dirtrider.net/forums3/sh...ad.php?t=146867
Posted by: defo26---------------------
I used castrol gtx 10w-40 in mine when temps were from 70-100+ degrees and castrol gtx10w-30 when temps were lower. Bike ran fine with it.
I wouldn't recommend using 10w30. In the cold you want a lower cold temp viscosity. A 0 or 5 weight would be better. The only difference between 10w30 and 10w40 is warm viscosity. You don't want to give anything up here.
Posted by: whenfoxforks-ruled---------------------
Which oil? Trans or engine?
Posted by: whizzit---------------------
Same oil for both, the crank case and transmission. I'd have to side with using 10w-30 oil though, for colder temperatures. Only because that is what my Honda operators manual states.
Posted by: 715---------------------
For '04 They Recomend Honda Gn4 10w40 Or Hp4 Semi-synthetic For Both Engine And Tranny. But I Believe In Some Cases Synthetic Is Too Slippery For The Clutch. I Use Regular Oil In My Trans And The Hp4 In The Motor For Mx.
