klx300 questions
Posted by: burlybilt---------------------
Just purchased a 04' klx300 w/mikuni 33mm pumper carb. Anyone suggest jetting set-ups for this carb? Also, bike is very"jerky" between accelerating/deaccelerating, not smooth unless you're in a postion of being able to "ease" the throttle off or on. Anyone know of a heavier flywheel available? Thanks Burly bilt
Posted by: destructo---------------------
The jerking has to be due to the 33 pumper carb, my stock 02 I had was one of the smoothest bikes I have ever owned, very smooth on and off the throttle, with the stock 34 CVK carb. I would jet rich and work my way backward until the throttle response crispened up, It has a pretty good sized flywheel weight from the factory.
