Electrosport Dual Sport Kit
Posted by: ThePearl---------------------
Has anyone on here added an Electrosport Dual Sport Kit - Dakar Version? For a 2002 KDX 200.
Anything I should know about? Hooked all of the electronics/wiring to board and mounted it and light shroud to the bike last night.(Easy)
Got to hook it to stator. Put rear blinkers on. Hook up taillight/plate holder. Plumb all of that lighting. Oh yeah, put in new stator.
I'm not much for electrical work.
Any problem areas I should be aware of?
Shayne
Got everything hooked up...but
I think the battery is no good. Hook it up to charger and blinkers work, High and Low Beam headlight work, Rear light works...
Hook up stator wires as kit says(I think), but stator won't run the lights. Battery is not taking a charge, but the stator should run this stuff(at least dimly) without the battery being up, right?
There are two yellow wires coming oof the new wiring harness. The kit says to plug these into the Yellow and pink wire coming off stator. Well only yellow, black and white W/red line wires coming out of stator. What do I hook to? I did the yellow & white W/REd, but bike won't even start with the white one changed(no fire to spark plug). If I hook to yellow and black, bike starts but no power to lights, etc.
Had an idea, but can't imagine that the kit would be made up this way. Is there any chance that the stator only charges the battery and doesn't run directly to the lights? If battery doesn't take a charge, maybe the stator is sending power, but battery just won't take it? Any Ideas?
