throttle adjustment
Posted by: oubowtie06---------------------
i want more response with my throttle i can pull the grip all the way down to full throttle but it doesnt have very mcuh response going back to its original postion it goes back up very slow is there anyway i can make it have a faster response?
Posted by: rmc_olderthandirt---------------------
Lube the cable.
Clean and lube the twist tube on the handlebars
Smooth the kinks out of the cable.
Replace the cable if it is kinked.
clean the carburetor
You might want to run an experiment or two to establish if the problem is in the twist grip or cable/carburetor. If you take the twist grip apart and get the cable free you should be able to pull on the cable and have it snap back. If it snaps back nice and crisp then the twist grip is hanging up. If it goes back slowly then the problem is not in the twist grip.
Rod
Posted by: njkx---------------------
Also check there is not too much freeplay in the cable.
Posted by: DirtDomain---------------------
i have a problem with mine too. it just seems that when i give it gas it takes like a second to actually go. and sometimes when im going and then give it some more gas like in 1st and it will start bogging out and almost quites but then goes back to normal ?!?!
Your problem is probably jetting.
Quite a bit different topic. Do a search on jetting
Rod
