Originally Posted by IndyMX
You need to pull the plug out of the side of the ignition cover, be careful when you put it back in, it will snap in two if you over torque it. (Guess how I know this)
(Really regretting that)|
The mark on the flywheel (electrical side) and the mark on the primary drive gear (clutch side) will not line up at the same time on their covers marks at TDC. They are out a few degrees.
