Riding on a sand track?
Posted by: slinger34---------------------
First time i was on a track was three weeks ago. It is sand and i plan on going back this weekend. The problem is as i got comfortable with making the jumps, on one the backend whipped out and i crashed. any tips on tire pressure, or how to bring the rear back straight after it whippes out would help out alot. New to being on a track so any advice would really hep out.
Posted by: spark250---------------------
The backend whipping out doesn't have anything to do with sand.
you probabaly didn't hit the jump square.
but if traction is an issue you could run your tire pressure on the low side
Posted by: IndyMX---------------------
Just a guess, but I bet you didn't land with the gas on..
I landed pretty much sideways off a good sized jump last weekend, but was able to save it, because I was on the gas...
I can only imagine how much it would have hurt had I been off the gas on the landing.
Thanks for the comments, The owner of the track saw me crash and he also said that if i was on the gas i would have saved it. But i was too beat up to try it again. one thing though, sand is alot softer then packed dirt.
It still hurts..
Posted by: _JOE_---------------------
Seems to be the bending/twisting that does me in when I crash.
And yeah, hit the throttle right before you land. It will help you land any jump better, unless of course there's a tight corner right after it. In that case try to use your legs to straighten out the bike.
