Im guessing not cause i might damage something else, but on the other hand whats the worst i can do damage the bearings more?
Originally Posted by IndyMX
or possibly the swing arm, if you let those bearings go...
Or due to the bad bearings, you could crash and break an arm or leg.. Your call. |
ranges higher than the on you have. For working on your bike a Craftsman torque wrench will be fine. They are around 60 bucks. Just for reference, a helicoil kit to fix a stripped bolt is about 35. You should have a higher range wrench anyway for the axle nut and steering stem nut.
I guess I should of cleaned/lubed them frequently which i am going to do from now on though, but hey im learning something on my bike everyday. Talk to everybody when its back together.
vBulletin Copyright ©2000 - 2013,
vB Easy Archive Final ©2000 - 2013
