How to size a rear spring
Posted by: rmc_olderthandirt---------------------
After going through the process of setting sag, adjusting compression & rebound I have come to the conclusion that I need a stronger spring (I am 190 lbs).
My bike is a 1997 WR250, not exactly something you find a lot of after market parts for.
I have been looking around and I see suspension shops that advertise springs. What I don't see is an order form that specifies the make/year/model of bike.
Two questions:
1) How do I establish the parameters of the spring I already have.
2) How do I order a new spring?
Rod
Posted by: _JOE_---------------------
You should check the static and loaded sag. The static(bike under its own weight) should fall within a certain range once you have the loaded sag set, if it's too high you need a stiffer spring. The spec should be in the service manual.
Posted by: Papakeith---------------------
If you've determined that your current spring is insufficient what its rate is doesn't matter too much. You can go here to find out what spring you need: http://www.mx-tech.com/?id=spring_generator
well, nevermind that it doesn't cover your year bike. Just give them a call. A couple of questions, and they can suggest a proper spring for your weight, skill, bike.
vBulletin Copyright ©2000 - 2013,
vB Easy Archive Final ©2000 - 2013
