Originally Posted by hellbertos
Given all the corrosion I'm inclined to think that I'll need to employ a few of the suggestions here. Any tips on brands of chem corrosion cleaners to try?
Also, any tips on the head (significant deposits) and cylinder(not too much)?? Corrosion cleaner and a small brush?? THe head in particular looks pretty bad. . |
Quick follow-up: Talked a shop that does marine restoration who offer soda blasting. The guy I spoke w/ said he does hot rod and moto resto's at home and offered up that the corrosion has likely damaged the part/thinned the metal to a point as to make it not worth reinstalling.
Granted he didn't see the items in question, but, just curious here... in case... in such a situation, would there be anyway to cost-effectively rehab a component? Like a machine shop that could weld it up and grind it out?? Just wondering in case it comes to that. Looks like the heads are not available new. |
If for any reason the magnesium case does catch fire, DON'T THROW WATER ON IT! That will cause it to explode. Just take it outside and order some hot dogs.
Originally Posted by Ol'89r
He is correct about the 'thinning of the case. Those cases have a very high content of magnesium in them. Most of the time they can be tig welded and remachined. But, if they are eaten to a point where they are thin, it is very hard to weld them without blowing through the case. Also, it's hard to find someone that can tig weld magnesium.
Soda Blasting will clean the case without removing metal like Bead Blasting or Sand Blasting will do. Also, soda is inert so, if a little is left in the case it won't hurt anything as opposed to sand or glass bead. After the case is blasted, check it closely for holes. lay the case on its outside and fill it with gasoline. Let it sit overnight. If the gas doesn't leak through, you should be good to go. The CLR will work on your radiators and hoses. Most of the crust in the hoses will come out if you take your hand and crush the hoses and then blow them out with compressed air. If you use the CLR in your radiators, be sure to rinse the radiators with DISTILLED water after you are done to neutralize the CLR. On the impeller, try using a little heat before removing it. Use a torch DIRECTLY on the impeller. This will expand the impeller and loosen its grip on the shaft. Be careful not to get the flame on the magnesium side case or your motorcycle will turn into a giant sparkler. If for any reason the magnesium case does catch fire, DON'T THROW WATER ON IT! That will cause it to explode. Just take it outside and order some hot dogs. For chemicals to treat or prevent rust and corrosion, check out this site---> www.eastwood.com |
Originally Posted by sm7482
Actually for our right crank cover we used a propain torch and some low heat aluminum welding rod. we heated up the areas we needed to weld then added the rod, kinda like soldering. it's worked well and our case didn't explode/catch fire ect.
If the case is magnesium, DO NOT USE OPEN FLAME ON IT. This is a very bad idea. Look on the side of the case. If it is mag, it will say magnesium on the case. Using open flame on a mag case can catch it on fire. Mag can be tig welded because tig welding uses an inert gas to eliminate oxygen from the welding area. Without the oxygen, the case will not catch on fire. Using open flame in an oxygenated environment is VERY dangerous with magnesium. Once it catches fire, you can't put it out.
The impeller is made of aluminum. It's ok to use a little heat on it to expand and loosen it instead of just using force and hoping for the best. Just using elbow grease is a good way to break something. The nut is not welded on the impeller, it is cast as one piece. |
very true indeed, our right case very well may have been made of aluminum, but even if mag is flammable the heat thats generated by heating the impeller just may ignite it no? was it cheaper to make an aluminum mag alloy than all aluminum? seams dangerous no? I would still try using wd40 or or similar to free the impeller than heat, .
Originally Posted by whenfoxforks-ruled
You are fortunate to have one of two years that the ama made the pros race what came off the assembly line. At the time, they were factory bikes.
At the risk of wearing out all the goodwill... I still have the corrosion issues which I am unsure about, as well as general rebuild questions (like how to remove the main bearings from the crank?? I guess I better start looking for a good machinist...) and I'm sure many future questions as the project goes on. Given this, I am not sure the etiquette for posting. Should I keep reopening this post or repost as new questions/problems arise?
Thanx SMMWest! Let me know if you find any extra PJ-1 paint in Honda orange. I looked around a bit but didn't find any. I'll look at the Chev engine paint when I get to that point, but, in all likelihood, if I do paint it I'll probably go to an auto paint shop and see if they'll color match.
BTW, I had an 85 CR125 way back when also. Sold it to get my 87. Loved that bike too. Nice work keeping it alive... and, in my opinion, nice work returning the frame to stock. I remember guys doing their frames white back then and never really liked it. I recall it being the "Euro" look. The custom aspect was cool but I guess I just thought the white clashed too much w/ the rest of the bike + got dirty and ugly fast... my fashion rant for the year... |
If your friend is an AP mechanic he should be sharp enough to help you through most of your rebuild problems.
Originally Posted by SMMWest
Couldn't miss a Child Support Payment, so it had to go.
