Originally Posted by juniordragster123
C'mon 7 views and no replies? I hope I have come to the right place for help.
So basically when the piston is going down the balancer counterweights go up to counter act all the rotational mass and balance it all out?
Thanks alot! I cant wait to get this bike running. What about the location of the camshaft timing gear and where it gets pressed on?
I mean the 15 or so tooth that gets pressed onto the crankshaft that drives the cam chain inturn driving the camshaft. That just gets pressed on whereever then you time the cam like you said?
Theres no spline at all. Just a gets pressed on. Why cant I just figure out where to press it on and press it on and just make sure its at TDC and make sure the two cam scribes line are level with the gasket surface?
Dude, I didnt take this apart some other guy did about 8 years ago did so you cant tell me I wasnt inclined enough to mark them first.
This isnt new to me as I drive a alcohol dragster
I slept at a Holiday Inn Express a few times and they still won't let me do Rocket Surgery.
..and I know what your saying and I have somone that can help me degree in the cam.
Originally Posted by Patman
A thousand pardons.
What has that got to do with ANYTHING? I slept at a Holiday Inn Express a few times and they still won't let me do Rocket Surgery. So then why the big fuss about "isn't there another way"? |
They both use the same engine don't they?
Bet it's fun to drive.
