Originally Posted by sharky243
DO NOT USE A DRILL BIT TO CLEAN THE JET !!! Let the parts soak for about a half an hour in the cleaner. Clean the parts off with varsol, spray carb. cleaner through all the passages, blow dry with compressed air. If you must use something to clean the jets, use a strand of fine copper wire. This won't damage the jet like a drill bit will.
Friday afternoon they are calling for +10 deg C
Originally Posted by Patman
Read the carb cleaning sticky I have at the top of the pitbike & mini forum.
