2006 KTM Fork Cap Tool - what's needed?
Posted by: twinpoint---------------------
Hi,
I have a 2006 KTM 300XC and want to pull the fork caps off. What tool is needed to do that and where's the best place to get it?
Thanks,
Rich
Posted by: D Lafleur---------------------
If it has 4 holes in the top, you will need the motion pro tool or similar. If it doesnt it should be 24mm or 25 mm socket/wrench. Dont forget to loosen the pinch bolts on the triple clamps if you are doing this on the bike.
Posted by: newkid---------------------
If you don't have the tool you can get 4 screws that fit in the 4 holes in the cap. Put one down in each hole, they don't screw in they just drop in. Then use a screwdriver to turn the cap off a quater turn at the time. Do remimber to loosen the top clamp pinch bolts. It is better to break loose the cap before you remove the fork from the bike.
I hope this helps.
