Originally Posted by Rabbit_Fighter
Ol'89r,
Thanks for that as I was wondering if I could check the plugs at any speed. Cold starting is easier, 5 kicks instead of 15. RF |
I think the accel pump is not being activated until about 1 third throttle. Shouldn't it be more like just as the slide starts to lift? I can see outside mechanical linkages and can observe that the plastic cam thing is not pushing down on the rod until the throttle is well and truly on. I guess I need to pull the carby off (ouch) and observe the slide and when the pump rod is pushed down? RF |
Ol'89r,
I will pull it off. Not sure at this stage if I can alter the point that makes contact with the rod. Thanks for the confirmation of this being non oem. It certainly works. Do you know what they usually fit the TM's to? Think this is a 36, though the oem was a 38. RF |
