Originally Posted by holeshot
But it was free (and it's still registered) so I can't complain.
Looks like a fun project. Those kerplunks are worth more than you paid for the whole bike. Oh, that's right, you got it for free. Even better.
Originally Posted by mxbundy
If you want to rebuild the Curnutts , I have a guy who can strip, rehard chrome the shafts and grind back to size.
But from what I understand the Curnutts are only good to use as spring holders! Ohlins would be the setup. When you get it fixed, come out and play with us. CALVMX.com bundy |
Well..I got this thing together and it starts and runs, but I've run into a little problem with the exhaust pipe. It seems that the OR and WR models came with a double walled pipe (quieter and heavier) but after 30 years ,the inner wall is coming apart. I've dumped out the pieces below --- some came out when I first got it, 1 more came out after I started it and ran it for a few minutes (and 1 more large piece remains floating around inside the pipe). The pieces will just keep coming off inside, so the pipe is basically junk and any other OR/WR pipe of this vintage is only worth it's weight in scrap metal.
Looking for a '79 CR pipe (single wall and lighter). Pic of pieces below Oh yeah, the bottom pic is a genuine Preston Petty front number plate/toolbox that was an aftermarket part in '70's - pure junk now ... but I've kept it as memorabilia ![]() |
