No damping at all - Mid valve blown?
Posted by: Pauly F---------------------
I think I need to replace my mid valve with a check plate. Where can I get a check plate? Also. How do I access the mid valve? I had someone do this once on my other bike and I remember some drilling was involved. I'm a machinist and feel competent in doing this job but just don't know all the steps. Please help
Posted by: IndyMX---------------------
Sounds like you could use a service manual. You can find on for your bike on the Australian Yamaha Motors website. I think it's under support.. look around, you'll find it.
Posted by: Pete Payne---------------------
You will be WAY better off with a properly functioning midvalve thean a check plate -- believe me !
Posted by: hot125mod---------------------
where and what is the midvalve again?
Is the compression stack the same as a base stack?
The midalve is the "active valve" it is the compession valving that is connected to the damper rod that is actualy traveling through (active ) the fork fluid. there is a mid-valve piston -on one side is the compression valving and on the other side is the rebound valving. This mid-valve valving has a dramatic affect on the damping .
vBulletin Copyright ©2000 - 2013, Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2013 - Created by Stefan "Xenon" Kaeser
