Help problem with new dirtbike!
Posted by: new2dirtbikes---------------------
I have a 2006 baja ssr200 i got it today cheap. Now im starting to think i got what i deserved. The bike started right up when i went to look at it. When i brought it home it didnt start at all it took me 2 hours to get it started. I shut it off and a hour later i went to go take it for a ride and the thing would not start at all. After about another 3 hours i got it to start. It was idling really funny backfiring alot then i noticed that the exhaust was starting to turn cherry red! I dont really know if that is supposed to happen but it was and it was from the engine and id say about another 8 inches up the pipe. Then i started to see something on my floor it looked like water being sprayed out of a spray bottle, it was gasoline. I shut the bike off and now i need help becuase if this bike is broken im throwing it through the guys front door. Thank you for any help you can give.
Start at the gas tank and work your way down to find the fuel leak and work from there.
Posted by: whenfoxforks-ruled---------------------
Does the bike have a carb or injected. Sounds like the valves need adjustment for 1 thing/ may be trashed? I have never heard of anyone riding, much less issues with a baja ssr200? Have you googled it?
Its got a carb. i tried googling it, but nothing came up thats why i came to a dirtbike forum. Anything about how hot the exhaust is getting??
Posted by: _JOE_---------------------
Sounds to me like the pilot jet is clogged. And you definately need to figure out where the gas is "being sprayed out like a spray bottle" before going any further.
Posted by: helio lucas---------------------
is this bike chinese looking? like a pit bike but a little bigger? i think it has same tires as 80īs big wheels? 19" front and 16" back?
i am asking this because thatīs why you cannot found any information, there are so many brands... try to contact a dealer that sells pit bikes... a good one...
Posted by: Matt90GT---------------------
First off the chinese bikes are JUNK JUNK JUNK. none of the wire leads are the same color, they dont know how to harden steel, the forks are dangerous on those bike. usually just grease and springs. best thing for that bike is to ghost ride it off a cliff. And the Baja brand is a junk brand. Joes retail chain sell them here and they are all junk.
ok got my rant over.
Sounds like the carb needs a good cleaning. pilot is most likely plugged. Getting the carb turned and the bowl off may cause a lot of stripped and/or broken screws. be warned.
lol yea thanks i got most of the kinks worked out and ill be honest i never heard of baja before i bought it but hey it was cheap and now i know why. maybe i can get someone to trade me for a 125 or something by kawasaki
Quote:
... or maybe the Tooth Fairy will bring you one
Posted by: 2strokerfun---------------------
There's a sucker born every minute. But I've never had the patience to actually find one.
