Now I have a 88 KDX and more questons.
Posted by: Maddog355---------------------
Well While looking for a seat on ebay I found a almost complete 88, The major needed items were the flywheel, stator, and cover. All of which seems to be intact and in good working order on my 86. Hopefully I will have the stator and such changed out in time to see if it will run tomarrow.
Now my questons are,
1: How much trouble is it to remove the flywheel? Will I need any special tools?
2: I have read there is a issue with them slinging the magnets off. Is there anything I can do to help prevent this while I have it down?
3: It apairently has a factory trail computer on it??? What are the functions of it???
Come on someone has to know something, I really want to get this thing running.
Posted by: glad2ride---------------------
You'll need to get a puller. I have used a car steering wheel puller and some bolts and washers.
I can't think of anything one can really do as maintenance on a flywheel beyond keep the taper clean on assembly. They just lost the magnets over the many years.
The stock meter is a combination trip meter and timer. It is an electrical unit, not a mechanical unit.
Posted by: sr5bidder---------------------
yes you can help you magnets not to fail if they haven't already
take the flywheel off or get the local shop to do it for $20 the factory epoxy is red and you need to inspect that..if it is flaking off the peel all loose stuff out and replace with a good quality 2 part epoxy and add some to the ends of the magnets ( between one end and the next magnet end where you will see they tapper back.
and before you start with the epoxy you should lightly pry up on them and see if they are loose... and if they are take the loose one out and cleen surfaces with contact cleaner made by crc and add epoxy to the back side aswell
note that the magnets are shouldered up on a nub in the flywheel put it back the same..
everytime I have seen failed magnets in the flywheel it appeared to be caused by miosture in the cover area and was very rusty inside if yours is not then your probably good to go just keep the flywheel dried out even if you have to remove the cover an used a hair dryer after riding or washing
Posted by: podfish---------------------
be careful not to tear up the stator underneath the flywheel. You can use a steeringwheel puller but make sure to use good quality bolts, and only go in 1/2 or so max. I had to get a shop to do it for me in the end, because I wasn't willing to apply the torque it ended up taking! the rotor can really hold on hard....
yeah man podfish when the one I did let loose it had a very sharp loud noise (sounded like something broke).
I think the propper puller threads inside the flywheel in the centerthen has a bolt through the center of that one of the hardest parts was holding the flywheel still while turning the bolt on the puller
"If we had three arms there would be no such thing as friends1"
The older flywheels have three threaded holes that bolts go into from a plate, but the 1989 + models use the 27mm x 1mm left hand thread puller.
thanks Glad2ride I could not remember ..someone adopted my 2 older kdx200's
How kind and thoughtful of him. :-)
