Toasting Spark Plugs????
Posted by: newfie1973---------------------
Just got a new 2008 sx250 - have 2 tanks of gas max burned and have gone through 3 spark plugs and the bike seems to be runnin rich!!!
Posted by: sloopy---------------------
are you mixing at 50 to 1? i think thats what the new ktm 2strokes suggest.
Hey - thanks for the reply.
I'm mixing 60:1 as per the manual.
When I say Rich - I may be wrong in my terminology - I mean seems like the bike is running heavier on oil - can even see where the oil is running out the exhaust!!!
Posted by: mdavidso---------------------
try a hotter spark plug it helped with my bike
Posted by: helio lucas---------------------
that rich has nothing to do with the fuel\oil ratio... itīs the fuel\AIR ratio... jetting it means...
Posted by: BSWIFT---------------------
Check out the jetting thread at the top of this forum. What oil are you using? Is the oil recommended to be mixed at 60:1? How does the bike run at various throttle positions? Lean/rich is determined by the fuel/air mixture and not the fuel/oil mixture so more info is needed to help identify the fix. The jetting thread is very helpful and very selfexplanatory. Quite a few members have installed the JD jetting kit with great results.
