yz465 putting on flatslide carb
Posted by: kiwiblues---------------------
hi, just wondering is it worth putting on a tm 38 flatslide. and if it is how does the jetting specs transfer from say a 390 main on the vm to what would the jet be on the flatslide the same?? does this go for pilot jet etc or is it all different. and how would it pan put.
or can ya just bolt em on
Posted by: TRexRacing---------------------
Sudco sells a 41MM custom flatslide for the 465.Take this with caution,a friend put flat slides on his RD350 and the jetting ended up almost the same as the round slide numbers.HOWEVER Dave is very good at jetting so you are on your own.I know you're on the other side of the planet but call Sudco they're decent with tech stuuf and may help you out.
http://www.sudco.com/
hmmm thanx for that, i guess it all comes down to money, but i will email sudco and see what they say
cheers
